Hi,
I have a 260z 2+2 with the origonal engine but with 240z carbs.......im changing the engine to an l28 but want to keep the carbs. is it just a matter of putting my origonal manifold and carbs onto the l28 or is there more to it.
thanks in advance,
Jay.
https://www.classiczcars.com/forums/topic/23651-l28-and-carbs/
Hi,
I have a 260z 2+2 with the original engine but with 240z carbs.......I'm changing the engine to an l28 but want to keep the carbs. is it just a matter of putting my original manifold and carbs onto the l28 or is there more to it.
thanks in advance,
Jay.
You will find the needles in the SUs will be fine in the L28 as well. At least for me at a near sea level the 54s are better all around than anything richer . I tried 47s and SMs and they were far and above too rich. I had gas in my oil from those needles . Are you parting out a 280 or just buying the engine ? I would check about the 260 cam. I cannot remember it it was internally oiled or had a spray bar. This is important if you were tempted to make a swap . Seems to me the 260 cam had a slightly higher lift. As Roger mentioned. Gary
The specs I've seen show the stock L24 cam with more lift on the intake valve than any other stock cam. But the L26 cam has longer duration and more overlap.
I think the spray bar was used until '77.
I'm able to get my hands on a complete l28 engine.....going to do a swop as my l26 is knackered.
thanks for all the help,
Jay.
Jay,
So that's how "swop" is supposed to be spelled!! Now my real question is "what the Sam Hill is that other word"? Nyuck nyuck
Jay,
Yeah, but those guys across the Pond are asking, "Who is Sam Hill?" LOL
