Hi Jerry/Arne:
Arne is correct - VIN's between HLS30 91591 and 95904 were all built 07/72. Your original engine serial number - from the Data Plate under the hood - should be between L24-113xxx and L24-120xxx.
You can order a new VIN Plate for the Drivers Door Jam from <a href=http://www.zzxdatsun.com TARGET=NEW>Banzai Motorworks </a>
FWIW,
Carl B.
https://www.classiczcars.com/forums/topic/23765-vin/#findComment-204132
Is the wording and layout of the door jamb VIN plate the same for all S30's? I realize the stamped info will be different as well as the year of manufacture, but is the rest of the plate the same from year to year? Anyone have any good pics? Thanks in advance.
https://www.classiczcars.com/forums/topic/23765-vin/#findComment-204685
