I found this on Craigs list in the barter area. It needs a lot of TLC but the floors and the frame are in good shape better than my 75.
The guy I got it from said it has not run in 5 or 6 yrs. He could not get it run
after he put a new clutch and injectors in.
I got it to run after I covered a big hole in the boot between the AFM and TB
it has a miss but she runs. Over all it will be a good project. In the pic's you'll see the hood is off the car before I left I put that back on I'm going back up to empire to drag it home this weekend.a>a>a>a>
https://www.classiczcars.com/forums/topic/23782-my-new-76/
Yes there is some old gas in the system it smokes maybe that will clear up.
The tail pipe ends under the rear 1/4panel and the smoke filled the car up so that there was smoke coming out the side vents. My first thought was a "Up in Smoke" movie. But for about 350.00 not a bad deal over all.
I'll get it home and check the compresson and see where I'am on the miss it has a N-42 Block and head I have a good head and a few other parts laying around to get it up and running. I wonder if the paint will buff out..LOL
https://www.classiczcars.com/forums/topic/23782-my-new-76/#findComment-204208
