I bought a Fridgidair A/C unit from a 73 240z that was an aftermarket unit. It is in perfect condition. My 72Z did not have air and I don't know where some of the parts connect. I wonder where the power to the control box connects under the dash. There is a solid wire coming from the control box, I don't know where this goes. also, there is a drain hose that goes through the firewall, does it connect under the AC unit or is that hole where the solid wire goes?
I am going to use a rotary compressor and mount it where the smog pump went. Should be the best of both worlds on a hot day.
Thanks
Bob M
https://www.classiczcars.com/forums/topic/23796-ac-install-question240z/
The 'solid wire' as you're calling it is most likely the capillary tube that inserts between the fins of the evaporator to sense the temperature and turn off the compressor when it gets too cold to prevent they system from icing up. The drain tube does connect to the bottom of the ac unit to drain condensation to the outside instead of on your inner firewall/floor/carpet etc.
Thanks Stephen
The temp sensor wire fits into the fins on the condenser, is this the unit in front of the radiator? Is there a particular place on the condenser that I should place it? I saw one email that mentioned it goes into the heater unit fins. I am going to use a rotary compressor from a Honda that is fairly compact. I hope this will work.
Thanks for your reply
Bob M
Thanks Stephen
Bob M
No, the sensor probe fits between the fins in the evaporator not the condenser. Take caution not to kink the tube. The Honda compressor should work fine if you can get it mounted and connected to the system.
