April 3, 200718 yr Author comment_204561 OOPS! NEXT Tuesday!!! Too bad, I always like meeting you guys in person. Maybe next week!Regards, Astrohog Link to comment https://www.classiczcars.com/forums/topic/23805-1270-1971-240z-electric-antenna/?&page=2#findComment-204561 Share on other sites More sharing options...
April 3, 200718 yr comment_204562 Zs-ondabrain The attached photos should give some clarity to the description of the 1973 Antenna. I believe the unit is original, and I imagine Harada was the manufacturer. There are no visible identifying marks to indicate that though. You will see that the Mast is approx 30cm (1ft) long when retracted. Thank you for your help. I hope one day to find the replacement Mast. Unfortunately many parts for our cars are NIL stock everywhere I try. Regards Jack Link to comment https://www.classiczcars.com/forums/topic/23805-1270-1971-240z-electric-antenna/?&page=2#findComment-204562 Share on other sites More sharing options...
April 3, 200718 yr comment_204563 That meeting is at Performance Nissan on 4/10/07 Next week. I will definately try and be there. The Datsun Work schedule is looking pretty full at the moment but next week could be better.Dave Link to comment https://www.classiczcars.com/forums/topic/23805-1270-1971-240z-electric-antenna/?&page=2#findComment-204563 Share on other sites More sharing options...
April 3, 200718 yr comment_204564 Hell Jack, I might have one of those in the garage. I'll check it out tomorrow and get back to you, Even if I don't have it.Dave Link to comment https://www.classiczcars.com/forums/topic/23805-1270-1971-240z-electric-antenna/?&page=2#findComment-204564 Share on other sites More sharing options...
April 3, 200718 yr comment_204565 Here's a couple eBay options for y'all.http://cgi.ebay.com/Datsun-280Z-260Z-240Z-280-260-240-Z-Antenna-Mast-NOS_W0QQitemZ180102683911QQcategoryZ46098QQssPageNameZWDVWQQrdZ1QQcmdZViewItemhttp://cgi.ebay.com/Datsun-240Z-OE-Power-Antenna-Great-Condition-No-Reserve_W0QQitemZ330103456431QQcategoryZ33639QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Link to comment https://www.classiczcars.com/forums/topic/23805-1270-1971-240z-electric-antenna/?&page=2#findComment-204565 Share on other sites More sharing options...
April 3, 200718 yr comment_204568 Zs-ondabrainThanks for that. As we say "You never know your luck". I shall look forward to hearing from you.As I have said, I don't know the Part No for the replacement Mast, so it is a little hard to be precise about the Item. I know the complete Antenna I bought on eBay LOOKED the same, but has a shorter Mast and a slightly different mounting arrangement. It also has a third wire - I assume for automatic operation. Mine certainly doesn't have that extra wire. It works, so will keep me out of trouble for awhile I hope.Thank you againRegards, Jack Link to comment https://www.classiczcars.com/forums/topic/23805-1270-1971-240z-electric-antenna/?&page=2#findComment-204568 Share on other sites More sharing options...
April 3, 200718 yr comment_204575 Zs-Ondabrain,Thanks for your offer to help! I did some searching and was able to find the antenna you mentioned on the shelf here locally (Best Buy) for under $60.00, PLUS I realized I had $25.00 of Best Buy Bucks in my wallet! It looks really straightforward to install (the key being the strap they include to cut/bend to fit!). I will be putting this one in this weekend and I have an appt. at the local car-audio place to install the head unit next Tuesday!It will be sooo nice to travel with tunes!! (might even make me forget about the fumes!!) haha!!!I will be heading to Z Specialties hopefully Tuesday afternoon to buy some asst stuff (including rear hatch weatherstrip, maybe the fumes will be a thing of the past!!) and then on to the ZCCW club meeting at Performance Nissan.Thanks again for your generous offer! Regards,AstrohogWhat kind of radio and what are you paying for it. You do know that That's what I do right? I am an NECP certified car stereo installer. I've been doing it for almost 20 years now.How about this one, for only $300. AM/FM/DVD/CD Video inputs as well as outputs, motorized face, 3.6" monitor built into the face. ANd plenty more, I'll find a picture in a minute Link to comment https://www.classiczcars.com/forums/topic/23805-1270-1971-240z-electric-antenna/?&page=2#findComment-204575 Share on other sites More sharing options...
April 3, 200718 yr comment_204583 Soundstream AV-VIR80043.6†Wide Din Size In-Dash Fully Motorized TFT Monitor/DVD/AM/FM Fully Motorized detachable 5 position drop screen with last angle memory DVD, CD, MP-4, MP-3, CDR, CDRW Player NTSC/PAL compatible All functions are displayed on screen via OSD (sixteen languages) 30-second electronic anti-shock mechanism SD Card Slot for MP-3 Music or MP-4 Movies (memory not included) Accessory I-Pod Input Connection (Cable not Included) USB mini input (excluding cable) for MP-3 Music or MP-4 Movies AM/FM with 30 pre-sets (18/FM – 12AM) Antenna trigger wire Amplifier trigger wire Brake screen safety trigger Telephone Mute trigger wire for Blue Tooth adaptation 4-channel high power 50 x 4 channels (MosFet power) Auto Store pre-set scan 5.1 outputs Dolby Digital Output (Front, Rear & 2-fixed freq. Sub) 1-Auxiliary Input for Back-up Camera 1-A/V in for secondary source input 1-Video Output LO/DX and stereo mono selector switch Electronic (Bass, Treble, Volume, Balance, Fader) Pre-set EQ functions (Rock, Pop, Classic) Digital Clock DVD, PAL/NTSC selectable Panel brightness 300 NIT ISO/DIN Mount Full function remote control 4 screen modes Last position DVD memory Link to comment https://www.classiczcars.com/forums/topic/23805-1270-1971-240z-electric-antenna/?&page=2#findComment-204583 Share on other sites More sharing options...
April 3, 200718 yr Author comment_204624 Dave,Excuse my ignorance!!! No, I did not know you did car audio! Otherwise, I wouldn't have made my appointment here! Send me a P.M. and let me know if you have any experience w/ the Soundstream products. I am not familiar with that brand, however, it looks like that one has it all!!! (no kitchen sink???)I can (and will) cancel my appt. here if you have units there and we can hook up sometime next week while I am on vacation (preferably Tuesday, April 10).P.M. me the details, cost, avail, etc. I will check my P.M. throughout the day as I can get Wifi, and I will get back to you!!Regards,Astrohog Link to comment https://www.classiczcars.com/forums/topic/23805-1270-1971-240z-electric-antenna/?&page=2#findComment-204624 Share on other sites More sharing options...
April 4, 200718 yr comment_204725 Zs-ondabrain.Just checking to see if you had any luck with the "Antenna Rod Kit" for the 240Z. I found a photo of such a Nissan Part/Box etc, but the photo is not clear enough to read Part No's however.I am finding the new menu a bit of a worry. I don't expect to get back to the Forums everyday and miss being able to access the older Post/Forums etc. Can anyone help??Regards, Jack Link to comment https://www.classiczcars.com/forums/topic/23805-1270-1971-240z-electric-antenna/?&page=2#findComment-204725 Share on other sites More sharing options...
April 5, 200718 yr comment_204806 Here's what I have found so far.METRA Part number 44-PWHD94 is a fuly automatic power antenna but it has a 31" (79cm) 5-section replacable mast and a 12" (30cm Cable) but I think the cable is the antenna coax. When I was looking in my book I was focusing on the 30cm part that you mentions but the book only tells me how many sections and how long it is when extended.They might be a big help so here's their number 1-800-221-0932I'll keep looking though,Dave. Link to comment https://www.classiczcars.com/forums/topic/23805-1270-1971-240z-electric-antenna/?&page=2#findComment-204806 Share on other sites More sharing options...
April 7, 200717 yr comment_205064 Dave,Thank you for maintaining the search. I will keep checking to see if you have had any success. A PM would be great if you have the time.Regards, Jack Link to comment https://www.classiczcars.com/forums/topic/23805-1270-1971-240z-electric-antenna/?&page=2#findComment-205064 Share on other sites More sharing options...
