First I know this topic has come up in the past. I just bought a 280z engine with an n42 head with 70k on it that i want to use until i build up my l26. What I want to make sure is will I be able to use my intake on the l28 so I can use the carbs (the ones on the l26 came from an early l24) from the l26? I read somewhere that the early efi fire all the time compared to the sequential firing in the later ones so I thought I might be better off transfering the SU carbs. Also I would need a fuel pump and Iam trying to keep cost to a minimum right now. Plus I really like the SU carbs. Anyone care to add and tell me what to do? Thanks Chris
https://www.classiczcars.com/forums/topic/23813-208z-engine-into-a-260z/
I installed a 280 ZX engine in my '73 and am running the SUs , that were on the old L-24 . No problems there either . there is a remarkable difference in performance and I think you will like the difference . The crank and stroke of the L26 is the same as in the L-28 the difference in the blocks is the bore size. the F-54 block has a different casting in the water jackets but other than that it also is alike. The L-28 , dished pistons , F-54, flat top pistons in the NA configuration and dished in the turbo version. Keep you present fuel pump it will be what you want with the carbs . In my Z I found the 54 needles to work the best. I tried different ones and came back to the 54s . I have headers and large exhaust and a street cam and thought I would need richer needles but found that was not the case for me. I live at near sea level . Gary
Thanks for the responses guys. Thats what I love about this site lots of helpful tips from people who have already done these things. I am looking forward to the swop. Now that we are on the subject witch would you build up the l26 or the l28 I will use carbs with what ever I do. I think I will prob do the l26 just so the original motor is in the car on the other hand I dont ever plan to sell or show it so I guess that isnt that important. So is one better to modify then the other? I thought it was interesting in the poll on this sight the n42 head is voted #1 and the e88 was voted #2. So either way I think it will be good. Thoughts?
Thanks for all the help. If anyone was watching e-bay I bought the L28 engine with N42 heads with 70K on it . I paid the buy it now price of $225. I talked to the guy and if its what he says I feel thats a good price he said it doesnt smoke and runs strong I guess Ill know soon enough. I guess even if the engine is shot I have the original L26 and now this L28 that I can make one good engine from. If you had the two and was planning a rebuld anyway should the two be combinded or just stick with one or the other? As I said earlier I was planng to rebuild the L26 and use the L28 until I was done, but now after reading all the post on the subject I am confused on what would be the best solution. I want semi stock a slight increase in HP is always welcome, but I still want reliabilty (HAHA) I only drive this car in nice weather and in North Western PA that is a rare thing however I drive it every chance I get. I have decided to use SUs in whatever I do. Is there any real disadvantages to the dished vs flat top pistons? I know copression is lower in dished but will I even notice in a stock engine? Thanks again Chris
