Posted April 4, 200717 yr comment_204763 Are the 510s the only other Datsun window crank that will fit on the S30's? Or will any of the "retainer clip" type cranks (pre1980) fit? Link to comment https://www.classiczcars.com/forums/topic/23838-window-crank-options/ Share on other sites More sharing options...
April 4, 200717 yr comment_204795 Most of the 65-85 window cranks will fit-take one off your car and take it to the junk yard to see what it fits-then you will know if what you like will work!WIll Link to comment https://www.classiczcars.com/forums/topic/23838-window-crank-options/#findComment-204795 Share on other sites More sharing options...
