As the title suggests this is about the L20ET, in particular I am after information on the best mod's for these engines.
I am after any first hand information on what you have done to one if you have ever owned or worked on one, what kind of power can they make with a decent bottom end and turbo, also how much porting and good cams that you know to work well.
I have just recently bought one, L20ET that is, and the plan is to put it into a Z, which I don't yet have but when I do it will have a new friend to play with as soon as I get it home. I have not as yet set a budget for the build, I know that's bad LOL but I am wanting to see first what they are capable of before i decide how far to go.
Thanks in advance for any suggestions and help with this folks.
Cheers
Stef
and no I don't want to go a late model turbo instead, yes I am a glutton for punishment LMFAO
https://www.classiczcars.com/forums/topic/23844-l20et-mods/
Unless you must have a 2 L six ,well I suggest you dont waste your hard earned .If you must have an L series, turbo an L28 put the 2 L rocker cover on and no one will know except you , these motors are " CRAPP".
