Posted April 9, 200718 yr comment_205313 Of three gauges in the middle of the dash, the middle light went out. Any one know the easiest way to replace and with what size bulb? It's a 1973 240z, just picked it up on Sat., do these cars have brights on them, I looked but I couldn't find any signs of them. Link to comment https://www.classiczcars.com/forums/topic/23892-dash-light-question/ Share on other sites More sharing options...
April 9, 200718 yr comment_205318 Argh. There is no "easy" way to change it. Something needs to be removed to allow access to the back side. The simplest is probably to remove the inner glovebox, although that's not as straightforward as it sounds.As for the bulb, it's a fairly standard small bayonet-type bulb. Don't know the bulb number off hand. But once you have one out, you can take it to the parts store and match it. Then buy at least 3 of them, and replace the bulbs in the other two center gauge bulbs while you can get to them.As for "brights", do you mean high beams on the headllights? If so, you bet they came with them, high beams are required by law. The dimmer switch is the turn signal stalk. Pull once to switch from low to high, and again to switch back.If you make it down to Eugene/Springfield some time, maybe we can look at it... Link to comment https://www.classiczcars.com/forums/topic/23892-dash-light-question/#findComment-205318 Share on other sites More sharing options...
April 9, 200718 yr comment_205324 I believe they are 9MM bayonet's But like Arne said, just pull one and take it to the store.Pull the T/S handle towards you or the steering wheel to go from hi to low beam.Congrats on the purchase,Dave. Link to comment https://www.classiczcars.com/forums/topic/23892-dash-light-question/#findComment-205324 Share on other sites More sharing options...
April 9, 200717 yr comment_205338 The light # is 194 JZM... Link to comment https://www.classiczcars.com/forums/topic/23892-dash-light-question/#findComment-205338 Share on other sites More sharing options...
April 9, 200717 yr Author comment_205356 thanks a lot guys! It sounds like this want be such a fun fix, but I should be able to find some time, now off to researching about pulling gloveboxes out...........I'll let you know Arne when I'm over in your area! Link to comment https://www.classiczcars.com/forums/topic/23892-dash-light-question/#findComment-205356 Share on other sites More sharing options...
