April 16, 20177 yr Author comment_518194 Today's work, rear stabilizer installation completed for 240ZG. I replaced spark plugs and distributer cap, rewarded a lot. Link to comment https://www.classiczcars.com/forums/topic/23900-datsun-240z-vs-fairlady-z432/?&page=61#findComment-518194 Share on other sites More sharing options...
April 16, 20177 yr comment_518195 Always nice to get hands dirty! Link to comment https://www.classiczcars.com/forums/topic/23900-datsun-240z-vs-fairlady-z432/?&page=61#findComment-518195 Share on other sites More sharing options...
April 16, 20177 yr Author comment_518196 I found a part number label on a prop shaft, I saw a memo of an original owner , he claimed vibrations soon after his purchase, dealer replaced it in late 1972. And fixing a inspection light, I like this original brackets, no cut out in one side like later one. Kats Link to comment https://www.classiczcars.com/forums/topic/23900-datsun-240z-vs-fairlady-z432/?&page=61#findComment-518196 Share on other sites More sharing options...
April 28, 20177 yr Author comment_519408 240ZG little work, houses changed, before and after. You see the green small plastic vacuum ball, that is a device which was required for emissions regulations in Japan started from 1973 . Even Z433 had to have it , most of them were installed at a periodically maintenance . The completed car had a sticker on the bonnet. Kats Link to comment https://www.classiczcars.com/forums/topic/23900-datsun-240z-vs-fairlady-z432/?&page=61#findComment-519408 Share on other sites More sharing options...
April 28, 20177 yr Author comment_519409 One more interesting device is, the electric valve for preventing dieseling. This work has done by the Nissan dealer, there is a memo of the original owner. "the engine still running after switched off when it is hot, need to be fixed" Then the dealer installed the device, you see the valve and extra tubes from the SU carbs, sucking fuel which should not go into the air cleaner box after the engine shut down. Wiper grommet new too ! Kats Link to comment https://www.classiczcars.com/forums/topic/23900-datsun-240z-vs-fairlady-z432/?&page=61#findComment-519409 Share on other sites More sharing options...
April 29, 20177 yr Author comment_519430 I am amazed that this thread started 10 years ago! Thank you so much everyone seeing and posting here to make this thread interesting. Here is a set of door molding, E4101 is the original non-plastic cap type. My Z432 is still improving a little bit, long way to it's originality. And spare tire holders, my 1972 240ZG has simple metal holders. No rubbers for the tap and the disc . You see the early ones came with the rubber for them. Kats Link to comment https://www.classiczcars.com/forums/topic/23900-datsun-240z-vs-fairlady-z432/?&page=61#findComment-519430 Share on other sites More sharing options...
April 29, 20177 yr comment_519435 A great thread! You are a teacher for most of it. Many thanks! Link to comment https://www.classiczcars.com/forums/topic/23900-datsun-240z-vs-fairlady-z432/?&page=61#findComment-519435 Share on other sites More sharing options...
May 4, 20177 yr Author comment_519880 Thanks Blue! A sticker added on the air cleaner . A crip added for the harness of the modified high intensity head light system. This crip is used for the battery cable on the fire wall, four of them for L -series engined car , three of them for S20 engined car. It was red , I wrapped it with a black tape. Looking great like a stock appearance. Kats Edited May 4, 20177 yr by kats Link to comment https://www.classiczcars.com/forums/topic/23900-datsun-240z-vs-fairlady-z432/?&page=61#findComment-519880 Share on other sites More sharing options...
May 5, 20177 yr Author comment_519932 An interesting modify of my 240ZG, this is the brace for the throttle pedal pivot. The original owner's memo said " throttle need to be more smooth when depress .." This is the solution , a dealer mechanic created unique parts, I think. Some car magazines claimed same thing, the throttle pedal was stiff and hard to control when start rolling. Kats Link to comment https://www.classiczcars.com/forums/topic/23900-datsun-240z-vs-fairlady-z432/?&page=61#findComment-519932 Share on other sites More sharing options...
May 18, 20177 yr comment_521223 On 2015-01-25 at 10:53 AM, kats said: Thanks everyone, the welded nuts are still misterious, however they seem to be for roll bar IMO. Alan told me the the distance between one nut and the other is exactly muches for a bracket of factory optional roll bar. But width between left two nuts & right two nuts is narrower than the roll bar's left & right vertical poles. If our car had the bars that attaches roof and floor , that would look stiff, but why have not ? I am thinking Nissan might allow the flexibility of the body structure , they would let the car's roof & pillers shake little bit rather than fixed otherwise the car would have crack in some area. What do you think of it? I will ask it to Mr. Uemura or Mr. Osawa , Mr. Miyazaki they will have some memories when they were testing S30 . Alan, did you enjoy chat with Mr. Osawa ? Nice to see you! Kats Link to comment https://www.classiczcars.com/forums/topic/23900-datsun-240z-vs-fairlady-z432/?&page=61#findComment-521223 Share on other sites More sharing options...
May 18, 20177 yr comment_521227 6 minutes ago, 240260280 said: That photo needs some explanation. It looks like a privateer/custom bracket fabrication to me? Despite the four captive nuts being in the rear header rail, I've never seen a factory or Works installation that actually used them. Certainly none of the Nissan Sports/Race Option four-point roll-over bars had them. I still think it's something that was mooted (hence those four captive nuts in that location) but never used for factory/Works parts. Link to comment https://www.classiczcars.com/forums/topic/23900-datsun-240z-vs-fairlady-z432/?&page=61#findComment-521227 Share on other sites More sharing options...
May 18, 20177 yr comment_521230 Hi Alan, Not much info on the part. It appears in a photo of shell HS30-00741 in Australia. The photos were taken a while ago. I saw the application then remembered Kats thread. Here is the Aus info: http://www.viczcar.com/forum/topic/13773-early-girl-bingo-with-photos/?p=192129 https://photos.google.com/share/AF1QipNl5Dbc6AlAPDlauRJ5eaLA8JMaql4Oee-fzrc9jUBQcg8UYa18piZD58gTZ1jLGQ?key=NVJGLU1oTGZvM1Y2VGx5Ymp2dW9UOGFIR3h4OGNR Link to comment https://www.classiczcars.com/forums/topic/23900-datsun-240z-vs-fairlady-z432/?&page=61#findComment-521230 Share on other sites More sharing options...
