Posted April 10, 200718 yr comment_205389 Ok, now that I have your attention!I have a Rally clock, that is missing a knob! I have recieved good information from Zclocks that the knob off the 280ZX digital clock is similar, and it is. (I have a bunch of new ones if anyone needs one) The attatchment screw, however, isn't even close!The rally clock Fastener isa standard slotted1.37mm in diameter(the threaded area) with.3mm thread pitch8.04mm in lenght overall including a3.15mm shoulderI have been hunting a similar screw on the internet and locally for several days and am no closer than I was the day I bought the clock.If you have a spare, or a good lead where one that fits could be found, I WOULD GREATLY APPRECIATE IT!Will Link to comment https://www.classiczcars.com/forums/topic/23901-member-in-need-of-a-good-screw/ Share on other sites More sharing options...
April 10, 200718 yr comment_205399 Will - Can you post a few pics of the screw from the other knob? Would they be identical? I have a wide assortment of screws of this type and will look through them and possibly find something you can use. I can gauge them from the measurements you gave but I am unsure of the shoulder detail. Is it a square shoulder? How wide & deep is the slot? Link to comment https://www.classiczcars.com/forums/topic/23901-member-in-need-of-a-good-screw/#findComment-205399 Share on other sites More sharing options...
April 10, 200718 yr comment_205426 Will, there is a local company near me appropriatly called "The nutty company" of Derby CT.They do have a website but I do not know how specific it is. Send them a email or if you like I can get there this wekeend to see if they have it. Link to comment https://www.classiczcars.com/forums/topic/23901-member-in-need-of-a-good-screw/#findComment-205426 Share on other sites More sharing options...
April 10, 200718 yr Author comment_205434 Ron, Jim,I'll post a pic an more details this afternoon, and it appears they are identical(the knob and screw fit either side).Thanks!Will Link to comment https://www.classiczcars.com/forums/topic/23901-member-in-need-of-a-good-screw/#findComment-205434 Share on other sites More sharing options...
April 10, 200718 yr Author comment_205450 Here is a measured drawing(pardon my lack of drafting training!) Please let me know if I have made this complicated enough-I can do better! Will Link to comment https://www.classiczcars.com/forums/topic/23901-member-in-need-of-a-good-screw/#findComment-205450 Share on other sites More sharing options...
April 10, 200718 yr comment_205451 That's perfect Will. I'll start going through my bins. I can probably make one if I don't find one. I usually use a mix of gun bluing to come up with the right color. Link to comment https://www.classiczcars.com/forums/topic/23901-member-in-need-of-a-good-screw/#findComment-205451 Share on other sites More sharing options...
April 10, 200718 yr comment_205457 geezer said: Is it a square shoulder? How wide & deep is the slot? Was This really necessary? Link to comment https://www.classiczcars.com/forums/topic/23901-member-in-need-of-a-good-screw/#findComment-205457 Share on other sites More sharing options...
April 10, 200718 yr comment_205491 Will - I came up with several, one in particular that would work. The only problem and I don't know if it would show once installed, is the 3.15mm head height you specified. It comes up short. Overall length is a little longer than needed though. I will try to get pics up later. Two other possibilities to find a better match would be an eyeglass outlet, or sign up on a model railroad site and ask them. Just don't show up back here wearing one of those big hats! Link to comment https://www.classiczcars.com/forums/topic/23901-member-in-need-of-a-good-screw/#findComment-205491 Share on other sites More sharing options...
April 10, 200718 yr Author comment_205495 Ron,When Installed the head of the screw is below the surface of the knob(I'll try to post a measured pic between diaper changes tonight), and it is recessed into the knob. The recess is not as deep in the 280zx digital clock knob either(once again, I'll try posting pics as the night unfolds).WillBTW, I git somethings in the mail yesterday-just cleared my wifes version of customs tonight! Link to comment https://www.classiczcars.com/forums/topic/23901-member-in-need-of-a-good-screw/#findComment-205495 Share on other sites More sharing options...
April 11, 200718 yr comment_205501 Nothing to help you but as you knew it would be: a very good attention getter. I will have to keep in mind for future use. Link to comment https://www.classiczcars.com/forums/topic/23901-member-in-need-of-a-good-screw/#findComment-205501 Share on other sites More sharing options...
April 11, 200718 yr Author comment_205514 Ron, Here is skinny on the knobs! Will Link to comment https://www.classiczcars.com/forums/topic/23901-member-in-need-of-a-good-screw/#findComment-205514 Share on other sites More sharing options...
April 11, 200718 yr comment_205529 Ok Will - That's enough information to come up with one suitable. The 3.1mm head height is to provide more support for the knob to keep it from breaking. The one I have in mind would work well with a washer of the same diameter bonded to it. I need to come up with another thread gage. I'm using a gauge from my metric SnapOn tap & die set. The smallest gauge is .35mm and the smallest die in the set is 3mm (useless in this case). That makes it guesswork until I get the thread measured properly. I'll do it tomorrow. A thread pitch of .30mm is tough to measure with a .35 gauge. Link to comment https://www.classiczcars.com/forums/topic/23901-member-in-need-of-a-good-screw/#findComment-205529 Share on other sites More sharing options...
