May 10, 200717 yr comment_209059 I got a space-saver spare tire from a Honda (15 inch) and one from an '84 300ZX today at the local junkyard. While the 300ZX wheel looks deep it in fact will NOT fit over the 240SX rear calipers. That's good because it weighs a ton.The Honda fits, just with a hair-breath of clearance. It now sits in my spare tire well.I will return the 300ZX spare and try and find another Honda. It wasn't in any specific car so I don't what year or model. Link to comment https://www.classiczcars.com/forums/topic/23910-sparetire/?&page=4#findComment-209059 Share on other sites More sharing options...
May 10, 200717 yr comment_209088 Do your rear calipers have enough meat on them to do a little shaving? You might increase your clearance with some careful filing or machining Link to comment https://www.classiczcars.com/forums/topic/23910-sparetire/?&page=4#findComment-209088 Share on other sites More sharing options...
May 18, 200717 yr comment_210027 As far as getting a flat. 1 of my tires exploded on the freeway lastnite. I don't think the slime would help maybe krazy or gorrilla glue... 1 hell of a puzzle tho. haha Link to comment https://www.classiczcars.com/forums/topic/23910-sparetire/?&page=4#findComment-210027 Share on other sites More sharing options...
March 17, 201015 yr comment_312767 I know this thread is old, but...what did you guys do? I have the modern motorsport 13" brake setup all around and will be going on a long drive this spring. (route 66) I thought of porsche, infinity, ect. with 17" wheels and those skinny spares. Adapter or redrilling will take care of the bolt pattern. I just need to fit over the calipers. So, has anyone figured it out?neal Link to comment https://www.classiczcars.com/forums/topic/23910-sparetire/?&page=4#findComment-312767 Share on other sites More sharing options...
March 17, 201015 yr comment_312769 Oh, I did try a 95 honda civic skinny spare. That don't work.neal Link to comment https://www.classiczcars.com/forums/topic/23910-sparetire/?&page=4#findComment-312769 Share on other sites More sharing options...
March 17, 201015 yr comment_312778 I found a compact spare at the local pick n pull. It only fits over the rears (240sx caliper conversion), but if a front fails, then I'll swap a rear to the front and put the spare on the rear. I can't tell you what car it's from since it was loose. Measure the min diameter to clear the inside rim, the max offset of the caliper from the hub face, and the diameter of your current tires. Then walk the JY with a tape measure Link to comment https://www.classiczcars.com/forums/topic/23910-sparetire/?&page=4#findComment-312778 Share on other sites More sharing options...
March 25, 201015 yr comment_313657 Looks like a trip to the JY. Thanks for your reply. I haven't been to a proper pick and pull since I was a kid. Kinda looking forward to it now. Link to comment https://www.classiczcars.com/forums/topic/23910-sparetire/?&page=4#findComment-313657 Share on other sites More sharing options...
March 25, 201015 yr comment_313660 I was thinking more of a round cardboard template that will just fit into the wheel that's on there. Just take that to the JY to try it in wheels. No tape measure is needed, and it's very quick; either go- or no-go. Link to comment https://www.classiczcars.com/forums/topic/23910-sparetire/?&page=4#findComment-313660 Share on other sites More sharing options...
July 1, 2024Jul 1 comment_666950 Resurrecting this thread.  I have the MilkFab rear disc conversion, and the ZcarDepot front larger brake kit - after my Volvo C30 broken wheel on the NY Thruway construction zone, I'm paranoid about driving the other cars with no spares. I'm going to Ohio in August in the Z - at this point I'm not longer comfortable running with no spare. Before anyone mentions it, I do have AAA, however being stuck for hours due to a flat is not something I'm willing to experinence (again) Some ppl mentioned using a Honda Accord spare - (I'm assuming '05-'06 range based on date of original post). EDIT - looking on line '02 was the last Accord to have a 4x114.3 bolt pattern. I have no access to JY, so I'll need more concrete input if possible, since I'll have to order one off eBay if I go that route. I would rather not get a full size  wheel & tire spare, as that will not fit in the well on my 75 Edited July 1, 2024Jul 1 by HusseinHolland Link to comment https://www.classiczcars.com/forums/topic/23910-sparetire/?&page=4#findComment-666950 Share on other sites More sharing options...
July 1, 2024Jul 1 comment_666951 5 minutes ago, HusseinHolland said: I would rather not get a full size  wheel & tire spare, as that will not fit in the well on my 75 Why won't a full size fit? I thought the 75 had the big spare well? They didn't change to the smaller spare tire well until 77. Link to comment https://www.classiczcars.com/forums/topic/23910-sparetire/?&page=4#findComment-666951 Share on other sites More sharing options...
July 1, 2024Jul 1 comment_666956 31 minutes ago, Captain Obvious said: Why won't a full size fit? I thought the 75 had the big spare well? They didn't change to the smaller spare tire well until 77. I have 205/50x15's - pretty sure it is too deep, that said, I didn't actually try one..... 🤪 Edited July 1, 2024Jul 1 by HusseinHolland Link to comment https://www.classiczcars.com/forums/topic/23910-sparetire/?&page=4#findComment-666956 Share on other sites More sharing options...
July 1, 2024Jul 1 comment_666957 Hmmm... Try one. It might be OK. The diameter should be fine. The only thing that might be an issue is the width, but in theory, you're less than .400 inches wider than stock. Maybe you're looking at a non-problem! Link to comment https://www.classiczcars.com/forums/topic/23910-sparetire/?&page=4#findComment-666957 Share on other sites More sharing options...
