Posted April 12, 200717 yr comment_205638 Greetings To All, I am in need of a 3 prong male connector like the one shown in the attached picture. This particular one is from the antenna switch cable on a 73 240Z. Would anybody have one of these they would like to part with or know where I could get one. ? Many thanks... Link to comment https://www.classiczcars.com/forums/topic/23929-need-a-connector/ Share on other sites More sharing options...
April 12, 200717 yr comment_205643 You can buy the entire switch which fits in place of the large blanikng plate. Check out my post in another thread.http://www.classiczcars.com/forums/showthread.php?p=211492#post211492 Link to comment https://www.classiczcars.com/forums/topic/23929-need-a-connector/#findComment-205643 Share on other sites More sharing options...
April 12, 200717 yr comment_205644 Hey Randy,If no one here has an extra one, try e-mailing Z Car Source. I've always had real good luck with them. They always seem to be able to get any hard to find Part for the classic Z Cars.There e-mail address is info@zcarsource.comBest of luck. Link to comment https://www.classiczcars.com/forums/topic/23929-need-a-connector/#findComment-205644 Share on other sites More sharing options...
April 12, 200717 yr comment_205669 If you don't have any luck elsewhere you could try Precision Wire Products in Hagerstown, Indiana. They have helped me out on a couple of replacement connectors. They build wiring harnesses and lots the connectors are standard. JLP Link to comment https://www.classiczcars.com/forums/topic/23929-need-a-connector/#findComment-205669 Share on other sites More sharing options...
April 12, 200717 yr comment_205674 The entire switch with the connector is under $10 plus shipping at nissanparts.cc as I said in the linked post and it's still available. Link to comment https://www.classiczcars.com/forums/topic/23929-need-a-connector/#findComment-205674 Share on other sites More sharing options...
April 12, 200717 yr Author comment_205691 Thanks to all who have replied here...Stephen,I checked out the Nissan site you referred me to and I plan on ordering that whole assembly. Thanks for the headsup on that one.Randy Link to comment https://www.classiczcars.com/forums/topic/23929-need-a-connector/#findComment-205691 Share on other sites More sharing options...
April 13, 200717 yr comment_205854 Check out http://www.vintageconnections.com/ and http://www.crc2onlinecatalog.com/connectors.htm Link to comment https://www.classiczcars.com/forums/topic/23929-need-a-connector/#findComment-205854 Share on other sites More sharing options...
