Front Calipers
vercingetorix
The unloaded calipers I put on my yellow car came from Schucks. They were just less than $30 each with no shipping, since I picked them up locally. They looked very nice, came with new pad hardware, and have worked well.
I generally prefer to buy calipers unloaded, as the pads are the easiest part for a rebuilder to scrimp on - and so they do. So I normally buy unloaded and pick my own name-brand pads to suit my needs at the time.
Thanks Arne,
Thats exactly what I needed to know. There is a Checker Auto here which is the same as Schucks. I can save shipping and core charge when I drop off the old ones as I pick up the new.
What are the best pads to use in order to avoid 240 squeal?
Thanks'
HH
I like Repco/Axxis/PBR Deluxe (not Metal Master) for a good, quiet, general purpose pad. Then I use Sta-Lube brake caliper grease on the piston-to-pad contact, as well as the edges of the pad backing plates where they contact the caliper body. I also use the grease on all the contact points of the top hold-down springs.
I'll second that emotion, regarding the REPCO pads......they work great and are nice to the rotors as well.
  • Who's Online   3 Members, 0 Anonymous, 531 Guests (See full list)
