Hey Will,
Got the windows out without a problem. One thing I would add it that once the screws are out and the seals have released grip, pull the bottom frame piece straight down. Gotta take time to work the old seals loose. The little corner moulding will bend if pulled at an angle. Do I have to apply sealer at the back joint where the rubber sits beneath the corner moulding, there was some there. Also found some rust inside the frame, will have to wire bush that out and prime it before the window goes back in. I'll contact you for the payment on the screws....
