Posted April 17, 200718 yr comment_206286 So the brake light located in the speedo is constantly on :mad: even with the E-brake handle in the down possition. I am in need of the relay that sits under the passenger seat. Does anyone have one out there that is not being used. This would be for a 1976 280Z. I have one from a 1978 280 but they do not interchange. I know this is the problem due to the fact that if you tap it with a screw driver or something like that it will go off for a bit and then turn back on. Link to comment https://www.classiczcars.com/forums/topic/23991-help-brake-light-driving-me-crazy/ Share on other sites More sharing options...
April 17, 200718 yr comment_206298 if I remeber right that metal relay seprates from the case and you might be able to clean it and check the tips of the contacts, good luck! Link to comment https://www.classiczcars.com/forums/topic/23991-help-brake-light-driving-me-crazy/#findComment-206298 Share on other sites More sharing options...
April 17, 200718 yr Author comment_206308 I will try and see if I can get it to comae apart. Link to comment https://www.classiczcars.com/forums/topic/23991-help-brake-light-driving-me-crazy/#findComment-206308 Share on other sites More sharing options...
April 17, 200718 yr comment_206312 The brake light also comes on when there's an imbalance detected in the braking system between the front and rear brakes. This could be from low fluid. I suppose you could verify that this is the problem by temporarily unplugging the lead from the sensor and see if the light only comes on when the handle is up. Link to comment https://www.classiczcars.com/forums/topic/23991-help-brake-light-driving-me-crazy/#findComment-206312 Share on other sites More sharing options...
April 17, 200718 yr Author comment_206327 Mike,I have done a total diagnosis on the problem and it is the relay under the seat. It drives me crazy. Link to comment https://www.classiczcars.com/forums/topic/23991-help-brake-light-driving-me-crazy/#findComment-206327 Share on other sites More sharing options...
April 18, 200718 yr comment_206346 I'll check the local wrecking yard and see if they have a one, BTW did you try looking a NAPA's website? They might have a new one... Link to comment https://www.classiczcars.com/forums/topic/23991-help-brake-light-driving-me-crazy/#findComment-206346 Share on other sites More sharing options...
April 18, 200718 yr comment_206352 Hey, I just checked the NAPA website and under the parts catalog for relays sensors and switches they have about 10 different ones, some have five blades and some with four. The good news is they have the oem part numbesr. BTW there called multi-function relays. They are not id'd by what they do however....I hope this helps..BTW do you have the part number? Link to comment https://www.classiczcars.com/forums/topic/23991-help-brake-light-driving-me-crazy/#findComment-206352 Share on other sites More sharing options...
April 19, 200718 yr Author comment_206478 I have not checked around at the auto parts stores I thought maybe someone had one in a parts car. I pulled mine apart today and found the problem was a bad wire coming from the coil inside and there was no way to fix it. O well. Link to comment https://www.classiczcars.com/forums/topic/23991-help-brake-light-driving-me-crazy/#findComment-206478 Share on other sites More sharing options...
April 19, 200718 yr Author comment_206486 Ok here is the part # 25230-N4300 It is located in the fisch on page 55-H-3 item number 36. Nothing from the local parts stores they don't carry that part. Link to comment https://www.classiczcars.com/forums/topic/23991-help-brake-light-driving-me-crazy/#findComment-206486 Share on other sites More sharing options...
April 19, 200718 yr comment_206505 Ok here is the part # 25230-N4300http://www.nissanparts.cc/cart/?pn=25230N4300 Link to comment https://www.classiczcars.com/forums/topic/23991-help-brake-light-driving-me-crazy/#findComment-206505 Share on other sites More sharing options...
April 20, 200717 yr Author comment_206649 Thanks MikeI will see if the local Nissan can get that for me. Link to comment https://www.classiczcars.com/forums/topic/23991-help-brake-light-driving-me-crazy/#findComment-206649 Share on other sites More sharing options...
