Posted April 20, 200718 yr comment_206705 I just got my tripple weber carbs on a cannon manafold sweeeet right, only it weighs a lot 25 or so lbs, I dont want to break my manafold studs is there a bracket or a brace to help support the extra weight. If not is there anyone that has made one? thanks Link to comment https://www.classiczcars.com/forums/topic/24031-tripple-weber-carbs/ Share on other sites More sharing options...
April 20, 200718 yr comment_206706 There isn't a part missing, if that's what you mean. I have seen people add a brace from the bottom bolt on the front and rear carbs down to the block. With the weight of the carbs and the exhaust hanging off one side of the head that's a lot of stress on the headgasket. Personally I ran mine with no brace for years and never had anything more than the usual headgasket seepage. Link to comment https://www.classiczcars.com/forums/topic/24031-tripple-weber-carbs/#findComment-206706 Share on other sites More sharing options...
April 30, 200718 yr comment_207685 awsome dude.the z i have now i modded for reliability,my old one my grandfather and I built for pure speed and performance Link to comment https://www.classiczcars.com/forums/topic/24031-tripple-weber-carbs/#findComment-207685 Share on other sites More sharing options...
April 30, 200718 yr comment_207710 Be sure to setup a heat shield too! Carbs don't like getting hot. Link to comment https://www.classiczcars.com/forums/topic/24031-tripple-weber-carbs/#findComment-207710 Share on other sites More sharing options...
