Posted April 22, 200717 yr comment_206905 lost my damn spec sheet whats normal for clear coat mix is it 4-1-1,4-2-1 or what I forgot and need to do it now! Link to comment https://www.classiczcars.com/forums/topic/24055-need-a-fast-clear-coat-mix-reply/ Share on other sites More sharing options...
April 22, 200717 yr comment_206906 I'm afraid I can't answer "what's normal" but what if your clear coat is not "normal"? You might be safer searching the web for an online spec sheet. You might also post exactly what you're using here in case someone else is familiar with it. Link to comment https://www.classiczcars.com/forums/topic/24055-need-a-fast-clear-coat-mix-reply/#findComment-206906 Share on other sites More sharing options...
April 22, 200717 yr Author comment_206907 its from napa , cant find anything online Link to comment https://www.classiczcars.com/forums/topic/24055-need-a-fast-clear-coat-mix-reply/#findComment-206907 Share on other sites More sharing options...
April 23, 200717 yr Author comment_206963 got it thnaks! Link to comment https://www.classiczcars.com/forums/topic/24055-need-a-fast-clear-coat-mix-reply/#findComment-206963 Share on other sites More sharing options...
