Posted April 23, 200718 yr comment_206939 Where do they go? I took my engine out 9 months ago, and am finally getting it back for Zdayz. I think the positive and fusible link go to the + on the starter selonoid, and the negative goes to the upper starter mounting bolt. Is that correct? (negative cable not yet installed) Link to comment https://www.classiczcars.com/forums/topic/24060-battery-cables-on-the-starter/ Share on other sites More sharing options...
April 23, 200718 yr comment_206944 That,s how mine is connected. Took the starter out today to clean the terminals as experiencing intermitent solenoid -starter clicking Link to comment https://www.classiczcars.com/forums/topic/24060-battery-cables-on-the-starter/#findComment-206944 Share on other sites More sharing options...
April 23, 200718 yr Author comment_206946 thanks! just wanted to double check Link to comment https://www.classiczcars.com/forums/topic/24060-battery-cables-on-the-starter/#findComment-206946 Share on other sites More sharing options...
