what goes on this connector?
2003z
The previous thread was about two wires that come through the firewall in that vicinity and go down to the automatic transmission. Because of the length required to reach the transmission they are long enough to reach the brake booster/wiper motor on the driver's side if someone chose to route them that way after swapping to a manual transmission.
Clean off the wires so you can see the colors and post them here.
It seems as though there is one Black, a Black/White and a Green, but this is simply by enlarging the screen and it could be wrong.
From those colors, my WAG is the Thermo Relay for an Automatic Transmission which was used to power the secondary points in the distributor.
FWIW
E
3 are black/white, 1 is Green/black.
There is a possibility that the wire goes inside the car, and not on the engine side, but I don't think so, as the engine bay was touched up in that area with some kind of thick black paint, which appears on the connector.
Its a 73 4spd, btw, and I can't find anything on the diagram that it could be.
None of my '71s have or had that connector, not in that location anyway. Not even the (formerly) automatic car. I'll try to remember to look over my spare wiring harness this evening.
