He did say oil. However if this was oil , I would think there would be lots of blue smoke. Like unkle said, likely it is just moisture condensing in the muffler and mixing with the soot coming out of the exhaust. Since he did say the engine is not wanting to idle. There may be a nozzle sticking when he stops using the choke. 1015 try this . pull the choke lever all the way back and then push it all the way forward, with the engine not running. then reach under the air cleaner and feel for he small hose that runs from the float bowl to the nozzle of the Carb. Push up on the adjustment nut and see if it clicks up. If either of them do this vary likely the problem . Also while you are there feel the hose to see if there stiff. A stiff hose will cause the nozzle to stick. If the nozzle sticks down it will cause a VARY rich condition . Gary
