Recently Browsing 0
I finally got my engine all back together and in the car and got to the point of starting it. It cranked for about 5-10 seconds then stopped. I thought it was the battery, but I've had it on a charger for over an hour and still nothing. I can see the engine move a little when the starter teeth engage the flywheel, so the starter is def. moving.
Is it possible for the engine to sieze with only turning that long? Is there a way to check if its siezed without pulling it and taking it apart?
What should I do next?
thanks in advance
https://www.classiczcars.com/forums/topic/24078-new-rebuild-wont-crank-anymore-help/Share on other sites
