Posted April 25, 200718 yr comment_207207 One of my freinds freinds was selling a ray jay turbo kit bolt on for a non EFI z....how does this work? and do you think its worth buying it for 300 for the whole kit Link to comment https://www.classiczcars.com/forums/topic/24089-turbo-carburated/ Share on other sites More sharing options...
April 25, 200718 yr comment_207208 Studebakers used a through the turbo setup...nothing new there, but that type of setup means seriously keeping up with your state of tune! If it is complete and in useable good shape as it sits, $300 is a good price.Will Link to comment https://www.classiczcars.com/forums/topic/24089-turbo-carburated/#findComment-207208 Share on other sites More sharing options...
April 25, 200718 yr Author comment_207209 yeah he just said you need to keep doing alot of adjusting Link to comment https://www.classiczcars.com/forums/topic/24089-turbo-carburated/#findComment-207209 Share on other sites More sharing options...
April 25, 200718 yr comment_207226 from what i've heard, SUs and turbo are not compatible, since the SUs require a certain amount of vacuum to work properly Link to comment https://www.classiczcars.com/forums/topic/24089-turbo-carburated/#findComment-207226 Share on other sites More sharing options...
April 25, 200718 yr comment_207233 For what it is worth, Corvairs used a carburator on their turbo motor for years. It worked fineBob M Link to comment https://www.classiczcars.com/forums/topic/24089-turbo-carburated/#findComment-207233 Share on other sites More sharing options...
April 26, 200718 yr comment_207239 Studebakers used a through the turbo setup...nothing new there, but that type of setup means seriously keeping up with your state of tune! If it is complete and in useable good shape as it sits, $300 is a good price.WillHi Will:What Studebakers used a turbo? I remember in the mid 50's and early 60's they used a belt driven supercharger, that pressurized the carb.. (Golden Hawk and Avanti)...I still think the 63 Avanti was one of the best designs of the decade, and wouldn't mind having one today.I think the 62 Olds Jet-Fire was the first tubo from GM, followed by the 63 Corvair Spyders.FWIW,Carl B.FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/24089-turbo-carburated/#findComment-207239 Share on other sites More sharing options...
April 26, 200718 yr comment_207253 For what it is worth, Corvairs used a carburator on their turbo motor for years. It worked fineBob Mya, i recall the good ol' turbo corvairs. but they used a standard doundraught carbie.lookin at maybe turboing DGVs or DCOEs? Link to comment https://www.classiczcars.com/forums/topic/24089-turbo-carburated/#findComment-207253 Share on other sites More sharing options...
April 26, 200718 yr comment_207261 You are looking at pretty old technology there, I might suggest that it would be a real challange to set up right and keep right.There is a brief article on draw through turbo conversions in the H.P. BOOKS "How to modify Datsun 510, 610, 240Z" [which in turn refers to the Hugh MacInnes book How to select and install Turbochargers"].The turbo used the downdraught Hitachi carb from the L4 series engines.You would need to seriously consider the lack of mixture control and ignition timing control with this system.In this day of off the shelf aftermarket EFI systems and decent sized intercoolers, I think you would be very disappointed in the olde school setup:ermm:Your choice, of course. Link to comment https://www.classiczcars.com/forums/topic/24089-turbo-carburated/#findComment-207261 Share on other sites More sharing options...
April 26, 200718 yr comment_207267 Back in the day - - - I had seen about four of these systems installed. Crown sold a kit for both the 240-Z's and the later fuel injected 280Z's.A local Z mechanic, replaced the single S.U. used in the system with a side draft Weber 40 DCOE. He built his own adaptor plates - to mount the Weber in place of the S.U.As I recall these systems recommended no more than 8lbs of boosts... but several of the guys ran 10lbs for years.... O-Ringing the head was also recommended by the kit manufacturers at the time (mid-70's).I agree with Nissanman that the old school kits do not really compare with running an L28ET with the factory or newer engine management systems, ect. Nonetheless, for $300.00 if the entire kit is there it could be some really cheap fun.... as long as you don't over-use it and blow an engine.FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/24089-turbo-carburated/#findComment-207267 Share on other sites More sharing options...
April 26, 200718 yr comment_207274 from what i've heard, SUs and turbo are not compatible, since the SUs require a certain amount of vacuum to work properlyI think all SU carbie turbos use a draw through type arrangement for that very reason. Link to comment https://www.classiczcars.com/forums/topic/24089-turbo-carburated/#findComment-207274 Share on other sites More sharing options...
April 26, 200718 yr comment_207275 Carl,Sorry I missed your post, The studbaker crowd has been using them for years-though they did not come from the (expletive deleted) that way!I have been getting a turbo news letter, 21st Centuray Turbos for years(it had been around far longer than I have been a subscriber), and it started out for the Studebaker crowd(I absolutley agree with you on the Avanti!). Interestingly, it is also available in book form published by a gentleman named **** Datson from Sarasota, FL.http://www.gatorsuperchargers.net/books/books.htm ).Will Link to comment https://www.classiczcars.com/forums/topic/24089-turbo-carburated/#findComment-207275 Share on other sites More sharing options...
April 26, 200718 yr comment_207276 Carl must have been referring to the Paxton supercharger that was an abailable (expletive deleted) option. Link to comment https://www.classiczcars.com/forums/topic/24089-turbo-carburated/#findComment-207276 Share on other sites More sharing options...
