April 27, 200718 yr Author comment_207352 Soooooo...When looking into replacement struts, do I need to compensate for the lowering of the chassis? It seems like you would need to adjust for the travel... Link to comment https://www.classiczcars.com/forums/topic/24096-new-ride-height/?&page=2#findComment-207352 Share on other sites More sharing options...
April 27, 200718 yr comment_207358 The less travel you have from rest to bottomed out, the stiffer the shock valving needs to be. That helps slow the compression motion down before it bottoms.Similarly, if you have a higher spring rate than stock, the springs really try to push back (think pogo stick), so increased rebound damping is necessary to compensate for that. Link to comment https://www.classiczcars.com/forums/topic/24096-new-ride-height/?&page=2#findComment-207358 Share on other sites More sharing options...
April 27, 200718 yr comment_207403 It seems like it is sitting a bit higher than it should.....Those Riken rims look fantastic on your car ZIII. Link to comment https://www.classiczcars.com/forums/topic/24096-new-ride-height/?&page=2#findComment-207403 Share on other sites More sharing options...
April 28, 200718 yr comment_207506 Thanks…. I keep toying with the idea of going with 16†Rewinds in gunmetal but I can’t seem to be able to do it. Link to comment https://www.classiczcars.com/forums/topic/24096-new-ride-height/?&page=2#findComment-207506 Share on other sites More sharing options...
