Posted April 27, 200717 yr comment_207327 Hey guys,I have a 72 240z that will not shift into reverse. I can shift into all four forward gears, but it will not shift into reverse. The clutch is disengaging properly and appears to be adjusted properly. It feels like something mechanical is not allowing me to shift. Any ideas on what the problem could be?Regards,Nathan Rolfe Link to comment https://www.classiczcars.com/forums/topic/24105-240z-tranny-problem/ Share on other sites More sharing options...
April 27, 200717 yr comment_207355 Broken transmission?I know that isn't helping, but... Link to comment https://www.classiczcars.com/forums/topic/24105-240z-tranny-problem/#findComment-207355 Share on other sites More sharing options...
April 27, 200717 yr comment_207389 Have you tried putting it into 2nd gear, then shifting into reverse? That is the only way I can put my car into reverse without that damn grinding noise. Link to comment https://www.classiczcars.com/forums/topic/24105-240z-tranny-problem/#findComment-207389 Share on other sites More sharing options...
