On my 75' 280 Z my oil pressure/tempature gauge does not work In the Hayes manual it says that the instrument voltage regulator could be bad. Does such a part exist? If it does, where is it, and could that be the problem? If it is not what can it be?
Jeff
https://www.classiczcars.com/forums/topic/2414-gauge-not-working-whats-wrong/
The very simple method of troubleshooting.
"Good in, Bad out you've found the culpritt"
I'm not yet an owner, but I am an Electronics Tech. Granted, $50,000 radars aren't auto gauges but they're pretty close.
What's the one thing they have in common?
A. power?
B. are they in the same cluster?
I don't know
If they are (B) If they're hooked up properly the chances of both senders being bad are slim. Most likely the Cluster should be replaced. The Gauge Voltage Regulator that the Haynes manual is refering to is more than likely in the cluster.
If I couldn't be any farther off even if I lived in a closet let me know.
The two most common problems on our boats are
A. It's not plugged in
and
B. Grounding, you've got to have a good chassis ground.
Happy hunting and good luck!!! :cross-eye
Recently Browsing 0
