Posted April 29, 200717 yr comment_207629 i am cleaning up my 76. unbolting everything and wiping everything down. this can hasnt been cleaned since at least 96. so sad. so it all looks good except for the booster and the big black bracket for the fusible links. then it begins. i could nt take it, so i took out the booster, the bracket thing, the coil and the bracket for the booster check valve. heres how the booster turned out. all i did was sand it with 180 and 400 sand paper, clean it, primer and paint it. i know its not a perfect match, but i does look really close to my 77 that is still shiney. opinions? thanks tony Link to comment https://www.classiczcars.com/forums/topic/24143-repainted-my-booster-what-do-you-think/ Share on other sites More sharing options...
April 29, 200717 yr comment_207639 That looks great! If you didn't tell us, I would have thought it was a pic of a NOS unit.What paint did you use? Link to comment https://www.classiczcars.com/forums/topic/24143-repainted-my-booster-what-do-you-think/#findComment-207639 Share on other sites More sharing options...
April 29, 200717 yr comment_207641 That looks super Tony. Link to comment https://www.classiczcars.com/forums/topic/24143-repainted-my-booster-what-do-you-think/#findComment-207641 Share on other sites More sharing options...
April 30, 200717 yr Author comment_207655 i used rust-oleum rust remover primer, then rust-oleum black gloss protective enamel(white can).thankstony Link to comment https://www.classiczcars.com/forums/topic/24143-repainted-my-booster-what-do-you-think/#findComment-207655 Share on other sites More sharing options...
April 30, 200717 yr comment_207659 Very nice job! Looks brand new. Did you just mask off the labels with masking tape prior to sanding and painting? Link to comment https://www.classiczcars.com/forums/topic/24143-repainted-my-booster-what-do-you-think/#findComment-207659 Share on other sites More sharing options...
April 30, 200717 yr comment_207668 Very very nice! Makes me want to do the same with mine! Link to comment https://www.classiczcars.com/forums/topic/24143-repainted-my-booster-what-do-you-think/#findComment-207668 Share on other sites More sharing options...
April 30, 200717 yr Author comment_207673 Very nice job! Looks brand new. Did you just mask off the labels with masking tape prior to sanding and painting?i used 3m blue painters tape. just carefully cut out the sticker. slowly. very slowly.then paint away. Link to comment https://www.classiczcars.com/forums/topic/24143-repainted-my-booster-what-do-you-think/#findComment-207673 Share on other sites More sharing options...
April 30, 200717 yr comment_207675 nice, from what I see in the photo's, the original sticker looks new! Link to comment https://www.classiczcars.com/forums/topic/24143-repainted-my-booster-what-do-you-think/#findComment-207675 Share on other sites More sharing options...
April 30, 200717 yr comment_207792 looks awesome!! Link to comment https://www.classiczcars.com/forums/topic/24143-repainted-my-booster-what-do-you-think/#findComment-207792 Share on other sites More sharing options...
