Posted April 30, 200718 yr comment_207771 Out of curiosity, does anyone know of a suitable 5 speed transmission for a '71 240z with a chevy 302 V8u conversion?-Mark Link to comment https://www.classiczcars.com/forums/topic/24156-v8-transmission/ Share on other sites More sharing options...
July 11, 200717 yr comment_214751 but I believe it doesn't handle high torque so well, so I am about to fit the T56 six speed. Just getting all the ducks in a row e.g. flywheel, appropriate clutch master cylinder, (to get a good balance between travel and effort, 'cos the T56 uses the internal hydraulic clutch thrust/slave cylinder), tailshaft, etc, etc. There is a bit of panel beating required on the transmission tunnel to fit in the reverse gear detent spring lock-out housing, but otherwise it should all fit in OK. Hope to be all done in a couple of weeks. Will let you know how it goes.Cheers. Link to comment https://www.classiczcars.com/forums/topic/24156-v8-transmission/#findComment-214751 Share on other sites More sharing options...
