December 7, 20159 yr comment_482496 On 12/7/2015 at 4:57 PM, jfa.series1 said: Cliff - that is exactly the process I used for my install. Also - lube the filler neck a bit to make it easier to slide into the plastic tube as you raise the tank. Jim Phooey - just realized I am responding to an old post. I offer the four hose grommet boots http://www.240zrubberparts.com/apps/webstore/products/show/4626636 Steve Link to comment https://www.classiczcars.com/forums/topic/24181-rating-the-factory-240z-fuel-vent-hoses/?&page=5#findComment-482496 Share on other sites More sharing options...
March 6, 20169 yr comment_487889 On 12/7/2015 at 5:28 PM, nix240z said: I offer the four hose grommet boots Steve Any chance you'll be stocking these again Steve? Edited March 6, 20169 yr by cnwayland Link to comment https://www.classiczcars.com/forums/topic/24181-rating-the-factory-240z-fuel-vent-hoses/?&page=5#findComment-487889 Share on other sites More sharing options...
March 6, 20169 yr comment_487905 On 3/6/2016 at 6:54 AM, cnwayland said: Any chance you'll be stocking these again Steve? Yes, they are on my list to make up in my next batch of parts. Steve Link to comment https://www.classiczcars.com/forums/topic/24181-rating-the-factory-240z-fuel-vent-hoses/?&page=5#findComment-487905 Share on other sites More sharing options...
March 8, 20169 yr comment_488079 March 2016 update i just ordered hoses and I'm in the process. Tank is down and out. Trying to figure out sequence of removing these very stiff hoses OUT. REASON IM WRITING found a source of metric hoses that are all modern fuel(ethanol ) rated Belmetric.com. A source of metric fasteners and hoses the braided 17 & 14 mm ...search RH17 and RH14 for CONTINENTAL vacuum, fuel , etc hose the 5, 8, 10 mm ...search RMH 5, 8, 10 FLENNOR Multi fuel hose 19 mm is not available now to the bends...They offer stainless hose benders. A wire wrap that supports the hose and makes the turn RHBEND 23.6 for for the 17 mm hose RHBEND 21.2 for the 14mm RHBEND 16.5 for the 8mm NOT cheap but the correct products. Sold by the meter I got TWO meters of the 14, 17, 8, and TWO ea 14-17 benders!!! TOTAL $199.64 free shipping. I think I could have gotten by with one meter but?? It's just money. The labor is what is kicking my but at 71. Link to comment https://www.classiczcars.com/forums/topic/24181-rating-the-factory-240z-fuel-vent-hoses/?&page=5#findComment-488079 Share on other sites More sharing options...
March 8, 20169 yr comment_488087 71!! You are my new hero. I did one when I somewhere around 41. Stayed in bed flat on my back for a whole weekend! Link to comment https://www.classiczcars.com/forums/topic/24181-rating-the-factory-240z-fuel-vent-hoses/?&page=5#findComment-488087 Share on other sites More sharing options...
May 12, 20213 yr comment_621502 From the 1972 FSM Link to comment https://www.classiczcars.com/forums/topic/24181-rating-the-factory-240z-fuel-vent-hoses/?&page=5#findComment-621502 Share on other sites More sharing options...
May 12, 20213 yr comment_621506 That's one of the many free FSM downloads this forum has. Link to comment https://www.classiczcars.com/forums/topic/24181-rating-the-factory-240z-fuel-vent-hoses/?&page=5#findComment-621506 Share on other sites More sharing options...
November 18, 20222 yr comment_647315 https://www.newcoproducts.com/index.php?route=common/home They supply braided metric fuel hoses as well as JIS blots. FWIW: the top hose from the eVape tank to the fuel pipe is 22mm not 19mm as shown. I used a 7/8" fuel line w/no issues. Q: Has anybody put a metal eVape tank into a series 1??? I got a hold of a metal tank and couldn't make it fit. Link to comment https://www.classiczcars.com/forums/topic/24181-rating-the-factory-240z-fuel-vent-hoses/?&page=5#findComment-647315 Share on other sites More sharing options...
