Hello All! I am in need of a distributor support - the part that bolts to the front cover and the distributor inserts into it. Attached is a photo. It is the bottom part, which has a bolt with a washer showing. I have one possibility locally, but wanted to check here too.
https://www.classiczcars.com/forums/topic/24184-distributor-support-needed/
I checked several bone yards last week, but nobody had an early Z or parts of one. I did pick up a support for an L16/18 thinking it might work, but the bolt hole on the distributor plate does not line up exactly with the one in the support.
