im thinking of purchasing a pair of rebello bored 50mm SU's, they used to pull 280 hp on a stroker engine, they are quiet a but cheaper then tripple webbers. since im not trying to get 280hp out of my L26, these lil pupies should do the trick with a ported head, mild cam and extractors. or should i spend the extra cash and go with the tripple webbers? keep in mind the webbers are almost 3 times as expensive, and im only using my car as a street car. any info that you guys might know about these bored SU's would be handy, and DO's or DONT's. cheers
Fuzz
https://www.classiczcars.com/forums/topic/24185-bored-sus-vs-tripple-webbers/
Fuzz
The SU's that Dave modifies are very happening and work well, as you know. The only thing I can think of to be aware of is that the needles are all custom profiled....not an off the shelf item. At least that's what Dave indicated to me. When I got my pair form Rebello and opened the box I just went WOW!!! They looked like jewelery, inside and out!
okay cool. no im currently running a stock head, but im going to port it and hopefully put a new cam in, when i take the old carbies off. so i imagine id have to find a needle which suits my car, and if im not wrong, there are over 300 different needles to choose from, guess and check would never work, how can i be sure to get the right needle? cheers
Fuzz
