Whats under your hood? 158 members have voted
  1. 1. Whats under your hood?
    • Pure 100% no mods
      50
    • pure w headers
      24
    • Stock block & head with diff. carbs
      15
    • Stock block & head but changed guts (pistons cam so on)
      9
    • stock block changed head
      8
    • Nonstock motor but still Nissan
      34
    • V-8
      10
    • No motor yet
      8
Please sign in or register to vote in this poll.
Mine is mostly stock. The previous owner did the following mods:
- 84.5 mm (83 mm stock) piston and ring set (Nissan Competition).
- High volume oil pump (Nissan Competition).
- Roadster oil pressure sender (Nissan Competition).
- Slalom grind camshaft (Nissan Competition).
- Steel seats installed in cylinder head, Head ported and polished.
- Variable timing cam gear (Nissan Competition).
- European curve distributor (Nissan Competition).
350 Chev with 4 bolt mains
Weiland single plane manifold
Roller rockers
Forged pistons
Strengthened rods
Short water pump
Mild turbo grind cam
Uprated ignition and leads
Predator Carby
Garret T04E turbo
equal length manifolds
Garrett ext 42mm wastegate..
waiting on custom made intercooler and aluminium radiator
hmmm thats about it...
  • 1 year later...
I got a mig welder, a heap of crap and a bonnet from a TR7 sitting under the hood if my Z. Have to put it back on when I get the front sorted.
In the car, I have got a stock L28 fresh from an 83 280zx (Aus spec) with the round top carbies, extractors and a 2.5inch exhaust.
Very plain I know, but still fun.
1973 240Z:
Chevy ZZ3 crate motor with:
Steel crank and pink rods
4 bolt mains
Roller cam and lifters
Aluminum heads (ported w/roller rockers)
Aluminum intake with Carter AFB 625 cfm
MSD ignition
Turbo 350 trans with lockup converter
Johns Car mounting system
1983 280ZX:
stock efi L28 with five speed
Nice to see an old thread come back......I wonder where all those people went. Funny how you never notice when a member leaves the site... some of those guys I haven't seen online in months.
I'm All stock. 3 Z's nothing added.........I want a stroker or turbo.
-Brandon
  • 1 year later...
F-54 flattop, early E-88 head (yall know there were 3 right) w 280 nismo valves, stage 1 port and polish, HKS 2mm head gasket, Slalom cam, Weber triple duece induction, equal length header, MSD fired by pertronix in Euro dizzy. Currently exploring the posibility of more cam.
260Z,Block crack tested bored to 3.1.Forged pistons,all the othe bits to go with it. some head work and not too leary cam,Pushing 255 BHP at the wheels with triple 48 dellortos,crap on juice,soon going over to throttle bodies,fitted with adjustable platforms with Eibach lowerd uprated springs,Willwood four pot calipers.0-60 time about 4.5 seconds,nearly forgot,skyline slippery diff
