Email logins are now active ×
turn signal dont work
choua1855
sorry to bring it back from the dead, but i have been having this same problem.
SO, i checked for the relay under the dash on driver side. Found it. I can hear it clicking on and off, but VERY VERY FAINT, and that's only when i do driver side turn signal. The pass turn signal doesn't even flash. If i pul hazard pully, all lights flash , (ie. front 2 orange, and rear brake lights.)
I was wondering if there is a seperate relay for the passenger side, and if maybe the relay isn't strong enough to push the power to the lights all the time. I will be cleaning out the connectors VERY SOON, but first wanted to check on here and see if it could be as easy as just the turn signal relay being bad.
Just to let everyone know, went to MSA today to pick up a relay and they charge $20 for it!!!!! I got the nissan part number and will be heading down to autozone soon to see if they can match it for a generic version. Hopefully much cheaper.
Another thing to keep in mind is the hazard switch. When the switch starts to go bad, the turn signals also suffer from it. If I bump my hazard switch just right, the turn signals will not work, until I play with the hazard switch, then they come back on.
The turn signals all go through the hazard switch.
Just throwing that one out to you guys. Just an FYI.
Dave.
  • 3 weeks later...
I haven't looked into it very hard and it seems obvious that the turn indicator is the issue. The right turn signal works fine, but the left turn signal is intemittent. I am assuming it is some sort of contact issue. Is a replacement required of simply a cleaning?
Tx,
Bill
  • Who's Online   0 Members, 0 Anonymous, 217 Guests (See full list)
