Posted May 9, 200717 yr comment_209022 Hi all,I know there's a thread on this somewhere but I could not find it. My question is this. Besides the ash tray will a 72 center cosole mount right up to a 70z with an August build date? Link to comment https://www.classiczcars.com/forums/topic/24279-72-z-center-console-same-as-70/ Share on other sites More sharing options...
May 9, 200717 yr comment_209025 The choke lever assembly is completely different as well. Best to stick with the early style console, which was used through 7/71 build at least, perhaps into 8/71. Link to comment https://www.classiczcars.com/forums/topic/24279-72-z-center-console-same-as-70/#findComment-209025 Share on other sites More sharing options...
May 9, 200717 yr comment_209031 My 11/70 has the early style console and the fast idle lever too. Link to comment https://www.classiczcars.com/forums/topic/24279-72-z-center-console-same-as-70/#findComment-209031 Share on other sites More sharing options...
May 9, 200717 yr Author comment_209035 OK, Thanks I guess I purchased this 72 version that is now worthless to me Link to comment https://www.classiczcars.com/forums/topic/24279-72-z-center-console-same-as-70/#findComment-209035 Share on other sites More sharing options...
May 10, 200717 yr comment_209047 The question was will it mount up. I don't think it's worthless to you though it might take a little effort to install it. I'll defer to the 240Z guys as to how much. I know the 280Z consoles interchange among the 280Z's but I'm not familiar with the fitment issues among the 240Z's. Link to comment https://www.classiczcars.com/forums/topic/24279-72-z-center-console-same-as-70/#findComment-209047 Share on other sites More sharing options...
May 10, 200717 yr comment_209050 Oh, I'm pretty certain it would fit in the car. But pretty much everything else would need to be changed along with it. The choke assembly, defroster switch, fuse cover, etc. There is also a possibility that the hole for the shift boot/lever is farther forward on the later consoles to match the Type B shift lever position. Might need a bit of tweaking there too. Link to comment https://www.classiczcars.com/forums/topic/24279-72-z-center-console-same-as-70/#findComment-209050 Share on other sites More sharing options...
May 10, 200717 yr comment_209067 I have a 72 240 that needs one, PM will be coming soon. Link to comment https://www.classiczcars.com/forums/topic/24279-72-z-center-console-same-as-70/#findComment-209067 Share on other sites More sharing options...
