Email logins are now active ×
a few q's regarding MSA header
hello all! i've read where a few people have had interference with the MSA header on the stock SU manifold. but all of them that i have seen this issue on (madkaw and marty rogan) were the 6-2-1 header; whereas i have the 6-1 header. does the intake interfere on the 6-1 header as well?
also, if i do decide to grind down the coolant passageways, will i have to weld anything? or is it just grinding?
one more question, how are you guys mounting your return springs if you aren't running the heat shield?
thanks guys,
Jason
  • Who's Online   1 Member, 0 Anonymous, 400 Guests (See full list)
