Clutch problems
spidee1666
Hi guys, I'm having a problem with a friends 240z I'm helping him work on. WHen I press the clutch in it goes in pretty easy and it's not working like it should. A mechanic friend said it probably needs a new master cylinder. I replaced that and it's still not working. Not sure if I just need to bleed the lines good? need to work on the slave? or if it's something worse.
Thanks for any help...you guys ROCK...
Ryan
