beandip Posted August 17, 2002 Share #13 Posted August 17, 2002 no that isn't true . I have been using the stock tach now for over a year , it just depends on how you hook it up. Link to comment Share on other sites More sharing options...
McZ Posted August 17, 2002 Share #14 Posted August 17, 2002 I check his site again to make sure and he did say a 240's could'nt be used. (His name is Bryan Little not Brian, my bad) How did you do yours? Not having to swap out tachs suits me just fine. Link to comment Share on other sites More sharing options...
beandip Posted August 19, 2002 Share #15 Posted August 19, 2002 When you do the hook up and connect the wireing if when hooked up the tach wont work you just reverse the wires and volia. there is a web site called zcar.com if you go there and select the early dates of 70-83 you will come up with a page like the forum here, in the upper border there is a search section key on that and then type in johnH240 and fine the posting on ignition up date . If you dont have any luck email me and I will help you ,but john has posted a step by step , also yoou can e-mail him , he really knows his stuff . He knows me as luggnut73 Link to comment Share on other sites More sharing options...
smg1404 Posted August 19, 2002 Share #16 Posted August 19, 2002 I run a Mallory dual point with the points. It works fine. I like tinkering and adjusting things, so I like the points. I get a feeling of acmplishment from properly setting the dwell, adjusting valves, and jetting carburators. It's fun to see the performance improvement when things are set correctly. The other stuff works fine, but if I wanted maintenance free I would get a new car. Link to comment Share on other sites More sharing options...
guy_geo Posted August 19, 2002 Share #17 Posted August 19, 2002 I got an electronic from a 280ZX, so AU REVOIR for the freaking points!!!! Link to comment Share on other sites More sharing options...
Victor Laury Posted August 19, 2002 Share #18 Posted August 19, 2002 Nissan EI converted dizzy by Gary Boone, custom machanical and vacuum curves. Full 12 volt ZX coil, so goodby points, goodby ballast resistor. Link to comment Share on other sites More sharing options...
beandip Posted August 20, 2002 Share #19 Posted August 20, 2002 What ever floats your boat. I prefer to drive my Z , I dont mind working on it at all , but driving it is much more fun for me. Besides the performance is so much better and the smoothnes of the overall driveability , for me is better after I pulled the duel point dist. . But that is my prefrence, all the best to you . Link to comment Share on other sites More sharing options...
bpilati Posted February 18, 2005 Share #20 Posted February 18, 2005 Just recently installed a Pertronix igniter and coil. Has not been the best experience, given the very bad technical advice I received from them. Link to comment Share on other sites More sharing options...
Zrush Posted February 18, 2005 Share #21 Posted February 18, 2005 MSD 6AL ignition with a Blaster 2 coil. Rev limiter on iginition is set at 6K. Works and runs perfect Vicky Link to comment Share on other sites More sharing options...
240ZX Posted February 18, 2005 Share #22 Posted February 18, 2005 Mallory Unilite w/vac.adv., MSD Blaster coil, Magnacore KV85 plug wires and the ubiquitous NGK plugs (gapped at.040")....on my (internally) stock N42 Fires up evevry time, hot or cold weather, and never skips a beat across the power band. Hey, just like then modern ignitions do!!! Link to comment Share on other sites More sharing options...
ChrisA Posted February 18, 2005 Share #23 Posted February 18, 2005 The old 72 I had (now Bill's) runs a 280ZX dizzy fired with a Accel HEI module. My 73 is MSD 6AL'd with Blaster 2 coil. Dizzy is single point but I'm looking toward Mallory or another ZX dizzy. Chris Link to comment Share on other sites More sharing options...
Bambikiller240 Posted February 18, 2005 Share #24 Posted February 18, 2005 Where is the freakin POLL?I have a Pertronix Ignitor in my 72 240Z and it works absolutely GREAT in my car. I followed the instructions given (to a "T"). It outperforms the POS Crane XR700 that I wasted $100 and a year of fiddling around trying to make the trigger optics stay in alignment and which FAILED on me causing the engine to just switch off at random times. (like in the fast lane of an interstate, or in the middle of an intersection) Link to comment Share on other sites More sharing options...
