i cleaned my connectors and changed the relay....is my turn signal switch bad?
Fabian,
That's a good start. I don't have a specific answer for your problem but you can sit down with an Ohm meter and the wiring schematic and work your way through the electrical system. I had a similiar problem where my headlights wouldn't work and I tried the connection cleaning also but I didn't make any progress until I got commited to fixing the problem using the right tools.
Yes your switch might be bad but you'll know for sure once you start tracking down the electrical current.
Good luck with your car.
Bruce
