7/8 or 13/16 cylinder
skyc110
Hi enthusiasts
for long time ago I thought that the rear cylinder assy.
is 13/16" dia , as what is written on it ( My 240K is 1976 )
I opened the cylinder from another 240K ( in my junk ) surprisingly
I found the cylider 7/8" !!!!!!!! so which is the original ? the 240K
which I have in my scrap collection run for two years only ( 1977-1979 )
as the scrap owner told me so I believe every thing on it is original ..
if any one can check his 240K ??
<a  href=http://www.upload2world.com/pic17/upload2world_dd4bf.jpg' alt='upload2world_dd4bf.jpg'>
It all depends on the FRONT brakes you have!
If you have the correct brakes for a long wheel base car then the front brake calipers have two pistons (one one either side of the disk) and you would be using the 7/8" cylinders in the back. Tokico was the usual supplier of this combination.
On the other hand, if you have the 'ANNETTE' type calipers on the front with a piston on one side only and a sliding frame then you would have 13/16" cylinders in the rear brakes. Nabco appears to have been the usual supplier of this combination.
The 'ANNETTE' brakes and 13/16" rear cylinders are supposedly only used on the short wheel base four cylinder cars but I have found them on two 6 cylinder sedans in Australia.
Same caution is needed re the manufacturer of the cylinder and the locking plates.
unfortunately I missed the parts manual which shows each and every
thing .....
generaly I don not like ANNETTE , ( pushing the rotor from one side may
bend it ( even slightly ) especially when it is hot ...
while pushing it from two sides ( with the same strength simultaneously )
keep him in balance and stability.!!!!!! whose that stupid engineer who
design the single piston ( ANNETTE ) ( actually it is not stupidity rather than
reducing quality ( some thing well known after 1974 up to today !!!!) )
any way 13/16 = 20.6375 mm while 7/8 = 22.225 mm so I will use the 7/8
TOKICO which I think it is stronger to stop our six cylider car !!
hope to find the repair kit ( 7/8" rubber and 126 dust cover locally )
