I am fixing thing ageter thing my latest 240z. Today is the fuel gauge turn!
It doesn't show any imput? From the sending unit I have 2 wires coming from the unit and one green and one black unpluged? What are they for? Cannot remeber wich is woich but one have male and the other female connector?
Any idea, pict, etc.
https://www.classiczcars.com/forums/topic/24378-fuel-gauge/
The fuel sending unit works like a variable resistor. It changes the resistance on the ground side of the guage circuit. The black wire is a ground, and the other one comes from the guage. You can test the operation of the unit by measuring resistance across the two posts. Mine was not working, I took it out and cleaned it with contact cleaner - it works great now.
I hope that helps a little bit.
Oh yeah, if I remember correctly, the black wire went on the bottom post - but i dont know if it really matters.
