Posted May 29, 200717 yr comment_210866 Hey guys, I searched the forums but couldn't find any thing about it but my tach needle gets stuck at 4,000 RPM's. The only way to get it back down is by tapping tachometer face until it goes down, not my favorite thing to do while driving. Anyone else have this problem and can it be fixed without removing the dash? Thanks Graham Link to comment https://www.classiczcars.com/forums/topic/24458-tach-needle-gets-stuck/ Share on other sites More sharing options...
May 30, 200717 yr comment_210899 I haven't tried tapping on my tach face. Mine just gets stuck on 3500, then it just starts working again, until it gets back to 3500. I have just been dealing with it and not letting it get me down. Link to comment https://www.classiczcars.com/forums/topic/24458-tach-needle-gets-stuck/#findComment-210899 Share on other sites More sharing options...
May 30, 200717 yr comment_210900 You don't have to take out the dash to remove the tach. There should be two screws holding it in on the back. Well that, the wiring harness and the light bulbs. Remove the tiny screws (damn japanese and their small hands) and the connections and you should be able to push the tach forward. Some models also have a screw just before the bezel inside. I believe it is at 12:00. Link to comment https://www.classiczcars.com/forums/topic/24458-tach-needle-gets-stuck/#findComment-210900 Share on other sites More sharing options...
June 3, 200717 yr Author comment_211213 Anyone know how to fix this or what it may be? Link to comment https://www.classiczcars.com/forums/topic/24458-tach-needle-gets-stuck/#findComment-211213 Share on other sites More sharing options...
June 3, 200717 yr comment_211214 If you are going to Canby we can talk about it next week end. Link to comment https://www.classiczcars.com/forums/topic/24458-tach-needle-gets-stuck/#findComment-211214 Share on other sites More sharing options...
June 3, 200717 yr Author comment_211219 Sorry a7dz, most likely wont, I'm only in highschool and the end of the year finals are coming next week and not to mention work. But there is always a chance, maybe.... Link to comment https://www.classiczcars.com/forums/topic/24458-tach-needle-gets-stuck/#findComment-211219 Share on other sites More sharing options...
June 19, 200816 yr comment_251299 Nissan Sucks Chevy Rules Link to comment https://www.classiczcars.com/forums/topic/24458-tach-needle-gets-stuck/#findComment-251299 Share on other sites More sharing options...
June 19, 200816 yr comment_251301 go away fixxor.Graham, I have the same problem with my Z. it only happens when it's really hot out, so I have a feeling the heat is what causes it to stick. in my case It sticks where ever it feels like. I'm not sure what the internals look like, but I wonder if the heat causes something to swell, or causes something inside to become gummed up Link to comment https://www.classiczcars.com/forums/topic/24458-tach-needle-gets-stuck/#findComment-251301 Share on other sites More sharing options...
June 20, 200816 yr comment_251321 fixxor said: Nissan Sucks Chevy RulesWhy are you here then? Don't hate on Nissans just because you can't fix yours. Link to comment https://www.classiczcars.com/forums/topic/24458-tach-needle-gets-stuck/#findComment-251321 Share on other sites More sharing options...
June 20, 200816 yr comment_251341 Sorry guys was logged in at work, saw my great coworker doing the deed but was too late. Please any mod delete that post and I apologize. Wont happen again. Link to comment https://www.classiczcars.com/forums/topic/24458-tach-needle-gets-stuck/#findComment-251341 Share on other sites More sharing options...
