Email logins are now active ×
Need help with header
choua1855
Since Last Week I Keep Hearing A Clicking Sound From The Engine Bay When I Step On The Gas. I Asked Someone Who Is A Mechanic And At First He Said It Could Be The Exhaust Header Or A Bad Spark Connection, But After A Search Through The Engine He Is 100% Sure It's The Header Because There Is A Crack On The Header Where The Bolt Is Located. I Have Never Heard A Clicking Sound Coming Out Of A Crack Header Before. Could It Be The Exhaust Header?
On 73 240z If I Want To Take The Exhaust Header Off, Do I Have To Take The Intake Manifold And The Carbs Off First? I Have Never Done This Before, What Do I Need To Know In Advance For Nothing Having Too Many Problems At The End For Removing All Of These Parts? Thanks Again
First off, is it an exhaust manifold or a tube header ? You said it's leaking around the bolt hole, which one ? You have the bolts that mount to the head and the bolts down at the collector that the exhaust pipe mounts to. A manifold is going to be cast iron, a header is going to be steel tubes.
When the exhaust manifold/header is replaced, you will need to replace the gasket too. The intake manifold and exhaust manifold/header share the same manifold gasket. So the intake manifold will need to come off as well.
first i thought the crack is on one of the exhaust header bolt but i guess i am wrong there are more than one crack now. please look at the picture. the cracks are on each tube of each header pipe. i dont know why there are small tubes on each header pipe.
the sound doesn't diminish after the engine is warming up, it actually gets worser after the engine warms up.
i found a header (MSA 3 into 2 Headers)from motorsport online store, does any one know do i need the one with smog or without smog and do these headers come with a gasket, if they don't, how or where can i find a good header gasket? thank you all again.
MSA sells a good header. Saul of MSA was at one of our Z club meeting and he told us the way he installs the header that they sell without it it leaking. I did not take notes on what he said so you are going to have to call him and ask. He will talk to you for sure. I recently installed one of the older MSA headers which were real prone to leaks, I used a medal gasket and cooper RTV, it started to leak a week later, so I re tighted the header bolts and it seems fine again. The newer MSA headers are supposed to be less prone to leaks, they improved the flange some. I went with the older MSA header because it was free.
  • Who's Online   0 Members, 0 Anonymous, 295 Guests (See full list)
