When you get the gasket, DON'T get the HD Header gasket. They are more britttle and prone to breakage and blow-out. Use the thicker regular gasket. They work just as good for the intake and last longer on the header.
That's what I did and Have NOT had any leaks or problems. But the header before that kept blowing my expensive HD header gaskets out. JFYI
Dave.
