Posted June 19, 200717 yr comment_212665 I was looking at MSA and debating on the Motorsport header or the 3 into 2 with the turbo exhaust. Opinions from the wise ones either way are greatly appreciated. Any real advantages on one header over the other? Link to comment https://www.classiczcars.com/forums/topic/24649-opinion-on-headers/ Share on other sites More sharing options...
June 19, 200717 yr comment_212680 Eric,Fist off there is a ton-O-info in the archives on headers....check it out! But basiclly, the 3-2-1 header works a bit better on the bottom to mid and the 6-1 header on the mid to top. However, with a stock motor you are not likely going to notice much improvement over the stock manifold. On the other hand exhaust tone will improve. Tom Link to comment https://www.classiczcars.com/forums/topic/24649-opinion-on-headers/#findComment-212680 Share on other sites More sharing options...
June 19, 200717 yr Author comment_212705 Thanks Tom. I did see a lot in the previous posts, I just wanted to see if there was an undying love for either of those headers. I just have a somewhat stock exhaust now that isn't seated well and I'm sure it is leaking. Either will be a vast improvement! Link to comment https://www.classiczcars.com/forums/topic/24649-opinion-on-headers/#findComment-212705 Share on other sites More sharing options...
June 19, 200717 yr comment_212707 Not to mention they provide nice sound too! Link to comment https://www.classiczcars.com/forums/topic/24649-opinion-on-headers/#findComment-212707 Share on other sites More sharing options...
June 22, 200717 yr comment_212977 240ZX said: Eric,Fist off there is a ton-O-info in the archives on headers....check it out! But basiclly, the 3-2-1 header works a bit better on the bottom to mid and the 6-1 header on the mid to top. However, with a stock motor you are not likely going to notice much improvement over the stock manifold. On the other hand exhaust tone will improve. TomInteresting info Tom, thank you. From my research I had always found that the 3-2-1 style was best...though you provide a bit more detail (low vs mid vs high end). Link to comment https://www.classiczcars.com/forums/topic/24649-opinion-on-headers/#findComment-212977 Share on other sites More sharing options...
June 23, 200717 yr comment_213049 I chose a 3-2-1 because im running on a pretty much stock car. I've read that if you plan to have a lot of motor upgrades that the 6-1 would be better. Link to comment https://www.classiczcars.com/forums/topic/24649-opinion-on-headers/#findComment-213049 Share on other sites More sharing options...
June 23, 200717 yr Author comment_213078 3-2-1 won, will be in next week. I'm leaving the round tops in and just replacing the cam in the fall so it should work out nicely. Thanks for the input guys. Experience is one of the best gauges of a product. Link to comment https://www.classiczcars.com/forums/topic/24649-opinion-on-headers/#findComment-213078 Share on other sites More sharing options...
