Posted June 21, 200717 yr comment_212823 didn't want to hijack stephen's thread, but i am having an issue with removing the crankshaft pulleythe bolts that came with the pepboys puller i bought are the wrong size, and i was wondering if anyone had any advice on where to find the right puller or what size bolts to use...anyone?Jason Link to comment https://www.classiczcars.com/forums/topic/24672-another-question-about-the-crank-pulley/ Share on other sites More sharing options...
June 21, 200717 yr comment_212824 I use they type of puller with three arms that clamp on the back of the pulley and a center stud that you turn with a wrench or socket against the crank snout. I bought mine at Harbor Freight. They're fairly inexpensive. Link to comment https://www.classiczcars.com/forums/topic/24672-another-question-about-the-crank-pulley/#findComment-212824 Share on other sites More sharing options...
June 21, 200717 yr comment_212825 Like these: Link to comment https://www.classiczcars.com/forums/topic/24672-another-question-about-the-crank-pulley/#findComment-212825 Share on other sites More sharing options...
June 21, 200717 yr Author comment_212830 so a 3-leg puller will work? i was reading in an older thread (ca. 2004) that these can damage the pulley.if that is not the case, then YAY! Link to comment https://www.classiczcars.com/forums/topic/24672-another-question-about-the-crank-pulley/#findComment-212830 Share on other sites More sharing options...
June 21, 200717 yr comment_212840 I've used them with no problems. Link to comment https://www.classiczcars.com/forums/topic/24672-another-question-about-the-crank-pulley/#findComment-212840 Share on other sites More sharing options...
June 21, 200717 yr Author comment_212844 excellent. off to pepboys after work. my car *should* be running this weekend Link to comment https://www.classiczcars.com/forums/topic/24672-another-question-about-the-crank-pulley/#findComment-212844 Share on other sites More sharing options...
June 21, 200717 yr comment_212847 If the hub is seized to crank nose or the rubber is in poor condition you can dislodge the outer ring from the hub using a three arm puller. The rubber literally shears or separates from the inner hub and outer ring. That renders a crank pulley useless. It would be better to acquire the proper bolts to use with a hub puller to ensure it comes off straight and causes no unnecessary damage. Link to comment https://www.classiczcars.com/forums/topic/24672-another-question-about-the-crank-pulley/#findComment-212847 Share on other sites More sharing options...
June 21, 200717 yr Author comment_212850 thanks for that recommendation....on that note, i know that the bolts are M10, but does anyone know the thread pitch? Link to comment https://www.classiczcars.com/forums/topic/24672-another-question-about-the-crank-pulley/#findComment-212850 Share on other sites More sharing options...
June 21, 200717 yr comment_212852 While I don't know the pitch off the top of my head I can offer a suggestion for the future. I went to my local hardware store and simply bought one each of metric nuts and bolts in the common sizes used by Datsun. You can store each pair in a labeled bag and can use them to verify sizes whenever you need to buy new fasteners. Link to comment https://www.classiczcars.com/forums/topic/24672-another-question-about-the-crank-pulley/#findComment-212852 Share on other sites More sharing options...
June 21, 200717 yr Author comment_212861 cool, thanks for the rec. Link to comment https://www.classiczcars.com/forums/topic/24672-another-question-about-the-crank-pulley/#findComment-212861 Share on other sites More sharing options...
