i am currently working on a sbc conversion, i am pulling my l28 out. my question is what is my l28 worth?? here is a list of what is included in the package.
engine:
L28 .040 over
n47 head match ported and polished
440/240 cam
high volume oil pump
su's sm needles
intake manifold match ported and polished
6-2-1 header
280 electronic ignition
jacob's coil and wires.
k&n air filters
280zx close ratio 5-speed trans
16 lb steel flywheel
factory clutch
ss clutch line
2 1/4" exhaust w/ turbo walker muffler
and only 25,000 miles on the motor. driven 25 miles to work each day via freeway.
thanks for any input.
ROFL
https://www.classiczcars.com/forums/topic/2469-whats-the-engine-worth/
Sounds like a really sweet set-up. I think you put-in more money to the engine than what you would probably end up getting. I kind of have the same set up as you and I wouldn't let mine go for anything less than 1k. Personally I think that is what it's worth. But what you get might be different. Good luck!
what's the engine worth?? Keeping
I am in the same boat. My engine for my 73 is fresh aswell . I was going ta put it up for sale too (sbc going in). After some thought. It's getting set aside. This way if later in life I would like ta sell ROFL Or just go back 6. It wont be such A big deal @ no cost.
This will keep me open ta looking around for A sick :sleepy: Z with A bad motor. Then you can get the best of bolth with liltle cost and know how it will run.
If you are like most Z people you should know better then ta think that this is your last or only Z.LOL
