Posted June 30, 200718 yr comment_213721 My L26 is in need of a rebuild so I bought an L28 from a 75 with 70k to use until Iam done with the L26. I am ditching the EFI and using my roundtops and was wondering if there is anything I should be aware of? The engine has the N42 head and from what I have read here it seems pretty cut and dry. The swap is being done by an experienced mechanic and I have the "how to book" and the Hastings book but thought I would ask the experts here for any advise. Thanks and Ill give an update after its all back together. Chris Link to comment https://www.classiczcars.com/forums/topic/24745-got-my-engine-today/ Share on other sites More sharing options...
June 30, 200718 yr comment_213722 Was the engine pulled from a running car? How recently was it started and used? If it has sat for a while, what are you gonna do to freashen it up? Link to comment https://www.classiczcars.com/forums/topic/24745-got-my-engine-today/#findComment-213722 Share on other sites More sharing options...
June 30, 200718 yr comment_213725 it is just a "bolt-in" procedure, but definitely make sure that the engine is not seized and that compression is good Link to comment https://www.classiczcars.com/forums/topic/24745-got-my-engine-today/#findComment-213725 Share on other sites More sharing options...
June 30, 200718 yr Author comment_213727 The engine was started and ran this year and the guy said it doesnt smoke or leak. I guess Ill know when I get it in. Anything about switching from EFI to SU I should know? The engine was pulled from a 76 not a 75. Thanks Chris. Link to comment https://www.classiczcars.com/forums/topic/24745-got-my-engine-today/#findComment-213727 Share on other sites More sharing options...
June 30, 200718 yr comment_213728 nope. no problems at all. Link to comment https://www.classiczcars.com/forums/topic/24745-got-my-engine-today/#findComment-213728 Share on other sites More sharing options...
June 30, 200718 yr comment_213731 mars23z said: The engine was started and ran this year and the guy said it doesnt smoke or leak. I guess Ill know when I get it in. Anything about switching from EFI to SU I should know? The engine was pulled from a 76 not a 75. Thanks Chris.From what I understand, an L28 is the same as an L24 and L26 but the bore and stroke are different. In any case switching to SU is no more difficult than changing the intake and exhaust manifolds out. I also plan to do an engine swap in the near future (L28ET from a 280ZX Turbo) but I will probably go through and change out the gaskets and and clean it all out before I drop it in the car. If you're pretty confident the engine you're going to use is in good shape and runs fine then I suppose all you have to do is pull your old one and drop in the new. Link to comment https://www.classiczcars.com/forums/topic/24745-got-my-engine-today/#findComment-213731 Share on other sites More sharing options...
June 30, 200718 yr Author comment_213733 Does the 76 have flat or dished pistons? I thought they were dished not sure Link to comment https://www.classiczcars.com/forums/topic/24745-got-my-engine-today/#findComment-213733 Share on other sites More sharing options...
June 30, 200718 yr comment_213734 dished if it has the N42 head.i thought of a few things that MIGHT throw you, but i don't think you'll have to worry about them on a '76 N42 head. on some L28 heads there is a connector on the head that you will not use. also, on later heads the boss for the mechanical fuel pump is filled. those may be moot points since you have an N42 head, though. Link to comment https://www.classiczcars.com/forums/topic/24745-got-my-engine-today/#findComment-213734 Share on other sites More sharing options...
June 30, 200718 yr Author comment_213740 I read in a post here that the 75 was dished and the 76 was flat so I wasn't sure.Thanks for the help Link to comment https://www.classiczcars.com/forums/topic/24745-got-my-engine-today/#findComment-213740 Share on other sites More sharing options...
