Posted July 1, 200717 yr comment_213767 What is the difference in psi for a cold engine compared to a warm engine? I did a cold compression test on my 280Z 2+2(I haven't got my fuel system straightened out yet and was told it may have a dead cylinder) today and found 85-95 psi for all 6. Is this normal? Warm engines for a 280Z should be 170-180. How much more pressure will I get once I have my engine running and warm? :paranoid: Link to comment https://www.classiczcars.com/forums/topic/24751-cold-compression-test/ Share on other sites More sharing options...
July 1, 200717 yr comment_213772 At least the compression readings are close to each other, that in itself is a good sign.Try dosing the cylinders with a squirt of oil, to help seal the rings, and repeat your test.The compression readings should increase.If the lowest reading is 75% of the highest, chances are the rings and valves are OK.Make sure the throttle butterfly are wide open when you do the test. Link to comment https://www.classiczcars.com/forums/topic/24751-cold-compression-test/#findComment-213772 Share on other sites More sharing options...
July 1, 200717 yr Author comment_213799 That helps. I was scared that 85-95 psi cold was too low. I think the engine might need to be broken in again after 25 years of not going anywhere.(the previous owner did start it in 2000). Link to comment https://www.classiczcars.com/forums/topic/24751-cold-compression-test/#findComment-213799 Share on other sites More sharing options...
