Posted July 1, 200717 yr comment_213786 Hey, I just finished redoing my head. If you recall a while ago, I was complaining about exhaust fumes in the cabin. I had replaced all seals and made sure that the cabin was completely tight. I had pretty much settled on the fact that I was going to smell like exhaust all the time. I started working on the motor, making sure that it was in good shape and I had a startling discovery. The PSI on 2 of my cylinders were non existent. It seems that every time the number 3 cylinder compressed it leaked into the number 4 and vice versa. I checked out the plugs and there was no residue on those 2 plugs. The other 4 were getting fouled and it seemed to be running really rich. Long story short. I pulled the head, valve guides, valves and pretty much everything else on the head was shot. There was even evidence of fuel-exhaust bypass on the gasket between the # 3 & 4 cylinders. I took the head to a machine shop, cleaned and adjusted the carbs, the exhaust has 4 leaks - fixed, but I should replace the entire system in the future. Put her back together and guess what. I no longer smell like fumes. There is not one trace of that nasty smell in the cabin. I can run with the windows up or down. She runs like a top - I checked the plugs after a 100 mile trip and they look great. Moral of story: If you have fumes in the cab like I did and are tired of trying to fix the small things, perhaps it is a major problem like no compression between cylinders and fuel leaking out of exhaust pipe and getting into the cabin of the car. I am almost finished with her. All I have left is to change the pinion bushing, replace the exhaust and fix a small noise that I have when I change gears very roughly. :love: Link to comment https://www.classiczcars.com/forums/topic/24754-exhaust-fumes-not/ Share on other sites More sharing options...
July 1, 200717 yr comment_213815 Congradulations Smells like your doing really well Link to comment https://www.classiczcars.com/forums/topic/24754-exhaust-fumes-not/#findComment-213815 Share on other sites More sharing options...
