Dash Lights
Shakey
No difference? At idle or while driving?
Unplug the "T" and plug the combo in to stock, measure voltage at the rear left sidemarker. Then reconnect the PLH into teh combo and measure the voltage again.
Measure at idle and over 1500 RPM. Post your results.
Remove the lens and paint the inner shell of the gauges.
Dave
Dave
thx dave, i'll do that once i get the chance. i have another electrical issue that will need the use of a voltage meter. any chance you can take a look at this thread and add your expertise?
http://www.classiczcars.com/forums/showthread.php?p=352209&posted=1#post352209
  • 1 month later...
